How to determine RESERVED Variable Values
June 27, 2008 12:00 AM
It retains the value of exactly what is written in the answer choice field. So, if the question is "2 + 2 = 4" and the learner sees the possible answers as "True" and "False," then the correct-answer value is "True." As I said originally, the correct-answer value is the actual text that the correct answer contains. (For MAMC questions, I think it's all of the correct answer texts delimited by commas.) It is not case-specific though -- that's one of the advantages of using FitB quiz questions over setting one up manually using a text-entry form field (which does compare the case to determine whether values match).Does that clarify things for you now? Laura
