How to determine RESERVED Variable Values
June 27, 2008 12:00 AM
I *think* I understand your question, so I'm going to attempt to answer it for you...The "correct answer" value for a question variable depends on the question type. For a T/F, MC, or FitB question, the "correct answer" value is the actual text that the correct answer contains. For matching (and, I think, drag-and-drop) questions, the "correct answer" value is "1-1, 2-2, 3-3," and so on, depending on how many correct answer pairs you have. Does that help?LauraP.S. Way back in one of the first versions of Lectora (maybe around 2004?), they provided a paper-based manual when you bought Lectora and that manual provided this info. I'm guessing that it might not be in the help file anymore because now you have the ability to "manually" test for correct-answer and incorrect-answer conditions by using the "Is Correct" and "Is Not Correct" operators.
