Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Solved
Lectora® #lectora-desktop
Report Abuse
Can anyone help its not letting me publish my scorm
@radillard
November 5, 2021 12:00 AM
Solution
@timk November 5, 2021 12:00 AM
Report Abuse
The error is described quite accurately ... make sure there are no "Go to" actions other than "Go to Next page" or "Go to Previous page".
View Solution in Discussion
Discussion (1)
Report Abuse
Join The Discussion
Sign Up Login
Rashaun Dillard
@radillard
View Profile
More From Rashaun
Text to Speech Isnt available
July 18, 2024 Reply 0 Upvotes
AICC Lesson status change.
May 21, 2024 Reply 0 Upvotes
Playthrough not seamless?
October 12, 2022 Reply 0 Upvotes
API Adapter?
Error "Action GoTo has an unresolved destination"
October 6, 2022 Reply 0 Upvotes
Installing Templates
January 20, 2022 Reply 0 Upvotes
AWT files
November 9, 2021 Reply 0 Upvotes
Lectora E-learnings not opening in Chrome
October 27, 2021 Reply 0 Upvotes
Limiting Test Attempts
August 10, 2021 Reply 0 Upvotes
"You must run this content from a web-based server Not Found"
July 22, 2021 Reply 0 Upvotes
Process Test Issue
Test in Reviewlink
July 12, 2021 Reply 0 Upvotes
© 2025 ELB Learning. All rights reserved.  | Terms of Use  |  Privacy Policy
Join The Discussion
Sign Up Login
