Issues with printing programs
I was just contacted by Trivantis Support and there is a known issue with V9 if you try to print and have a menu object in the program it will crash and not print. If you remove the menu object it should resolve the print issue. I have chosen to leave V8 on until the next service pack fixes the bug; since I need to print on almost a daily basis and use menus all the time in my programs.I was just contacted by Trivantis Support and there is a known issue with V9 if you try to print and have a menu object in the program it will crash and not print. If you remove the menu object it should resolve the print issue. I have chosen to leave V8 on until the next service pack fixes the bug; since I need to print on almost a daily basis and use menus all the time in my programs.
