Flash Navigation sample won.t run
September 20, 2007 12:00 AM
I'm after some help with Flash button navigation.I can't get the Flash Navigation example 2004-12-29_144540_FlashNavWithLectora.zip that Aaron provided to navigate between pages in Internet Explorer. The Flash buttons appear correctly but no navigation takes place. I get the same problem on Flash buttons I've imported into a course which use the following command to jump to a page:on (release) { getURL("javascript:trivExitPag e('pagename.html',true)"); } I've tried this on two PCs and get the same problem. Both have the latest Flash player running. Is this a Flash security settings issue and if so how do do bypass these?ThanksNick
