Background Problems
July 14, 2009 12:00 AM
1. How to Keep the Background Image from Repeating
It appears that the easiest way to keep it from repeating is to make it the same size as the page specified in the title. If it is different, frequently it will repeat. If you want to stop that, create an HTML object at the title level so it will be on all pages. You can shrink it down so it does not get in the way of your design. It is only a place holder.
In the Custom HTML box enter this:
From my book on Javascript Communication Secrets (Yes I know this is CSS but I put all my HTML, CSS, and Javascript stuff in one publication.)
