Matching Question Issue
February 3, 2009 12:00 AM
A great way to present this would be to have "bins" of answers. Then you just drag each component inside the bin to mark it. Sadly, I could not pull this off in Lectora. I guess that's kind of mean of me to suggest a possible route only to say that it can't be done in Lectora.I tried to create a question just like this. I ultimately gave up and went with a multiple choice question. I did spruce it up by creating buttons of images. When the questionable item came up, the learner clicked on the button to demonstrate that it belongs there. It's not the same as a bin, but it worked.So, to translate that to your question, you could create buttons of the album covers (WARNING: I'm not a lawyer, so check the legality of this). Modify them in your favorite photo-adjusting tool for the OVER and/or DOWN states. Fore example, enlarge them by 10% for OVER or invert all the colors for DOWN. At least it would spruce up your multiple choice question, if you had to go that route. Kevin
