Matching Question Issue
February 3, 2009 12:00 AM
I was under the impression that Distractors were simply extra choices to make the matching question more difficult, so you would have unused, or unselected, choices on one side. I need to have multiple answers for one selection. For example, I would need the choices "Two Step" and "Lie In Our Graves" to both match up to Dave Matthews Band. If I set them up as distractors, it does not let me select a correct answer for a distractor, therefore only allowing me to match one choice on the left with one choice on the right.I was under the impression that Distractors were simply extra choices to make the matching question more difficult, so you would have unused, or unselected, choices on one side. I need to have multiple answers for one selection. For example, I would need the choices "Two Step" and "Lie In Our Graves" to both match up to Dave Matthews Band. If I set them up as distractors, it does not let me select a correct answer for a distractor, therefore only allowing me to match one choice on the left with one choice on the right.
