Embedding Flash and Audio
Solution 1 should work... Were the "slides" folder and the "narration" folder in the same directory for the original course? If the links to the .mp3 files are relative the .swf will look to that link from the html file it is being loaded from, not it's physical location. What I'm saying is if in the original course the "narration" folder was within the "slides" folder then the Lectora version would have the "narration" folder right inside of the Lectora generated HTML folder. If the "narration" folder and "slides" folder were side by side then the "narration" folder should be right next to the HTML folder. Maybe I'm just rambling, but I hope this makes sense.Solution 1 should work... Were the "slides" folder and the "narration" folder in the same directory for the original course? If the links to the .mp3 files are relative the .swf will look to that link from the html file it is being loaded from, not it's physical location. What I'm saying is if in the original course the "narration" folder was within the "slides" folder then the Lectora version would have the "narration" folder right inside of the Lectora generated HTML folder. If the "narration" folder and "slides" folder were side by side then the "narration" folder should be right next to the HTML folder. Maybe I'm just rambling, but I hope this makes sense.
