Flash Audio - talking over each other
Flash audio is great to use, but I'm not the brightest at figuring it out. I'm using Lectora 2006 and publishing to HTML and ultimately to SCORM/Learn.com.Here's the deal: I've got 3 buttons on a page, all of which are set to play a different swf audio file. I can play the swfs fine but if I click button1 then click button2, it plays audio2 right over the top of audio1 (same for audio3). How can I stop the current audio and only play the new audio? I've tried putting them in a group and stopping the group first but it's not working.Here's what I've tried.- swfs are all set to initially invisible.- swf1, swf2, swf3 are all in a group "Audio".Actions on each button:- on click: stop Audio- on click: show swf- on click: play swfThis doesn't work - the swf1 doesn't play. It does work if I remove the "stop Audio" action, but then swf1 plays on top of swf2 and swf3 if I press those buttons. I've tried the above both in HTML preview and also published to a web server.What am I missing?Thanks,Russ
