Embedding Flash and Audio
One problem, a few possible solutions. The problem: Our developer and I can't get a Flash course to mark completed in our LMS (Learn.com). Neither of us are SCORM experts and I'm not a Flash or Dreamweaver expert and we haven't been able to figure it out so we're moving on to other solutions involving Lectora. BTW, the Flash uses a separate .swf for each page and each page is tied to a separate .mp3 file for audio.Solution 1: Put each .swf on a separate page in Lectora. This works fine in run mode but when published to .html the .mp3 file doesn't play. The original dir structure has each .swf file and it's corresponding .html in a "slides" folder and the .mp3 files in a "narration" folder. Embedding the .swf into Lectora places the .swf in the "images" folder and since the .swf is looking for the audio file to be in "narration" it doesn't play the audio. I tried copying the narration and slides folders to the root directory within .html then editing the html file for the page to look for the .swf in the slides folder but still no audio. Solution 2: Have the course launch and host the course, similar to what is mentioned in this post. The course plays in it's own frame and wants it's own directory structure. My problem is that I don't know how to embed a course like this within Lectora without making a change to the Flash file. Is this possible?I realize we can embed the audio into each Flash piece and that will solve the problem but I'm trying to figure out a solution without having our developer redo the entire Flash piece.Not sure if I've provided enough information but I'd appreciate any help you can offer.Lectora Version: 2006 sp5; Flash Version: Flash 8 Pro.Thanks,RussEdited By: rhall01 on 2007-3-13 10:40:12
