Cordinating objects to display with audio
December 12, 2008 12:00 AM
I've found this to work with timing to sound:First listen to your sound file and notate when you want the boxes to transition in and out, then:Right click on Text box/left click properties/left click Transitions tab/click Transition In option, then set timing according to your sound file. To transition out, click Transition Out option and set timing. I've found that the box won't actually transition out unless you ALSO Add an action.For Action: under General Tab, select: On - Show/Action - Hide/Target - select the text box you want to hide.Do the same for each text box.Hope this helps.
