Cordinating objects to display with audio
No there is no easy way. You need separate boxes.And the transition timing will get you in a lot of trouble. The audio does not always download at the right speed, getting your timing out of wack.Best bet is to use the audio editor that comes with Lectora Professional. You can set events, things to happen at certain times. Then when you open the properties of the audio box, you will see an Events tab. Select the event you want and then Show the text block relating to the bullet you want to have shown.
