Cordinating objects to display with audio
December 12, 2008 12:00 AM
Why do you say that? dsl4ou is trying to sync up the showing of text boxes with the audio. Using events is the only reliable way I have heard of to do that. How would the Captivate solution help?Why do you say that? dsl4ou is trying to sync up the showing of text boxes with the audio. Using events is the only reliable way I have heard of to do that. How would the Captivate solution help?
