Cordinating objects to display with audio
As long as the original poster's intent is to simply display the text at specific times, the Captivate solution would work. I've used that trick a few times myself. In fact, for displaying bullet lists one item at a time, I prefer Captivate's timeline interface to Lectora's delay interface. Although, if you need more than that, then things get tricky. As I understand it, you can't necessarily do things in Lectora based on what happens in Captivate. There are some things (like waiting until the Captivate movie finishes playing), but I don't know about adding more interactivity. So, if you're cool with just an animation that displays according to audio, Captivate should work fine. In fact, Camtasia would probably work too (but I haven't used Camtasia yet). Of course, if you don't own either of these tools and only have the audio editor in the Suite, then give that a try instead. Kevin
