Cordinating objects to display with audio
I have. It works with a time line. You just mark events at the times you want things to happen. Then when you add the audio object, it will have an Events tab. On that tab, you just select the event you want and it has a place for an action. You can show something, or if more than one action, run an action group to hide the previous object and show the next one. Or you can put the Hide action on the object just shown (On Show, Hide previous text box).I have. It works with a time line. You just mark events at the times you want things to happen. Then when you add the audio object, it will have an Events tab. On that tab, you just select the event you want and it has a place for an action. You can show something, or if more than one action, run an action group to hide the previous object and show the next one. Or you can put the Hide action on the object just shown (On Show, Hide previous text box).
