Cordinating objects to display with audio
This feature has been a godsend, and like Ben says you get Event markers that can launch into pretty much anything an action normally does. I'm using the Event Markets to launch Action Groups to fade out a Text Box and Image and simulataneously fade in a different Text Box and Image. The actions in the group are set to toggle visibility state so if you have a long series you can set the first image as initially visible, the rest as initially hidden and then copy two of the 4 actions into each following action group to save time.
