Controlling Flash with EI
September 23, 2009 12:00 AM
I was looking around on the forums hoping that there would be a solution for this. We really want to control Flash with Lectora, even if its as simple as just sending ONE variable to flash and having it change even just the X,Y position or something.
Unfortunately, I don't even know what the flash code would look like for this. You mentioned that if I revert back to AS2, it will work?
stflowers: Have any examples of the Flash code for something like that?
