Controlling Flash with EI
September 23, 2009 12:00 AM
I've used the Lextensions Flash Communicator for a while, and it comes in very handy for alot of flash back and forth communication. And its crossbrowser which helps.
approg said:I'm trying to get Lectora 9.3 to control a SWF under the Flash Player 10 with ActionScript 3. In the SWF I have some AS that look like this ExternalInterface.addCallback("loadMovies", loadMyMovies); function loadMyMovies(str:String):void { // blah } Within Lectora I'm using an action with Action: Flash Command Target: mySWF Command: Call Function Name: loadMovies Value: foo.swf When I HTML publish the course and run it off a web server IE 8 complains that there's an error (a generic one in the SWF's javascript). If I hand build a HTML page for the SWF the calls to the SWF behave as expected. Can anyone provide some guidance on how to get this to work within Lectora? Andrew Poulos
