Audio and Pictures Transitions problem
February 15, 2007 12:00 AM
RussBradley here, we chatted in the past. I dont think you are stressing out Lectora in the least. However, I have had much difficulty in getting transitions to Exit properly, oh, I can get them to come in fine, but the exit is not so smooth. This too didnt work for me.To rectify this I simply create the images states and have them not visible initially, then create an action script to show the item at the interval, and then another action script to remove the image if you want it to leave... this works much more consistently for having things appear and dissapear vs using the transitions.Try this with a few images and get back to me. You can also email me at bfredrick@cmsstl.com or zip the .awt and email it to me to take a look at.Hope this helps.
