Variable Help: Show/Hide Caption Text
March 23, 2007 12:00 AM
markmarino wrote:
a) The area on the interface where I am displaying the narration text is not white, so the box I am using to cover the text area is set to use the custom color of the inteface background, and it becomes slightly visible when I publish to HTML [it is completely invisible in Lectora itself]. I am pretty sure this is a dithering issue, so I may be able to change the interface color to one that doesn't dither when exported. Did a little more research on this part of the problem, and it turns out that Internet Explorer has a bug that causes it to render PNG files in a slightly incorrect color gamut, and I am using a PNG as the page background graphic. Displays perfectly in Firefox. Thanks Microsoft!For anyone interested more info on this can be found here: http://en.wikipedia.org/wiki/Portable_Network_Graphics#Web_b rowser_support_for_PNGI swapped the graphic out with a GIF version and the rectangle is no longer distinguishable from the background color.Still need help figuring out how to prevent the text block from flashing on the screen before the rectangle covers it.-mark
