Using Sections in Tests and % Accuracy to Continue
September 17, 2009 12:00 AM
Just tested this using www.scorm.com.
If you have more than one test in your course, the scores get averaged together and posted to the LMS as the single score for your course. So, break your test sections and content sections into regular chapters and test chapters. Then you can use the On Passed and On Failed tabs on the test properties to control where the learner goes next.
While this may complicate things more, you probably should tell the learner somehow why they are being returned to the beginning of the chapter. To do this you will need to have special pages, one for Passed and one for Failed with next buttons that send them to the appropriate place. You will probably need to have a pair of these pages for each test.
