Using Sections in Tests and % Accuracy to Continue
September 17, 2009 12:00 AM
I don't know if this will work, but have you tried creating a test at the end of each chapter? Can set it to 75% and set the when passed tab to move forward, the when failed tab to go to beginning of each chapter. If you're putting this on an LMS I don't know the implications for scoring the final test, but this is one way to try.
2hawks said:I have a module with 6 Chapters. I want review quizes after each chapter, with the following function: If correct answers = 75% then continue to next Chapter. If < 75% then GoTo beginning of Chapter to review. Can someone point me to the correct way to set this up, please?
