Using Sections in Tests and % Accuracy to Continue
September 17, 2009 12:00 AM
Hi, Ben,
That is what I did first; separate chapters, and separate tests at the end of each chapter. I set up the first test with On Pass: Goto Next Chapter. On Fail: Goto Oops Page, (contains explanation of why you are here, and how to next proceed) followed by a timed auto redirect to the beginning of the chapter for review.
However, I can't make it accept the 75% accuracy requirement to go on to the 2nd Chapter. All results go to the Oops page. I suspect the problem has something to do with setting up the Results Tab (currently set at "74").
Is there any place that describes how to set this type of conditional statement?
2hawks said:I have a module with 6 Chapters. I want review quizes after each chapter, with the following function: If correct answers = 75% then continue to next Chapter. If < 75% then GoTo beginning of Chapter to review. Can someone point me to the correct way to set this up, please?
