Using Captivate controls in Lectora
This is problem we're having. I create the movie swf in Captivate along with the skin/controls. I can't get the controls to show in Lectora. or rather, if the controls show, then the movie doesn't. It seems I can't use the skin when this is shown in IE. So I'm forced to anticipate where the user might want to pause and put in stop/continue buttons embedded in the movie instead of being able to use the control bar from Captivate.
Any suggestions?This is problem we're having. I create the movie swf in Captivate along with the skin/controls. I can't get the controls to show in Lectora. or rather, if the controls show, then the movie doesn't. It seems I can't use the skin when this is shown in IE. So I'm forced to anticipate where the user might want to pause and put in stop/continue buttons embedded in the movie instead of being able to use the control bar from Captivate.
Any suggestions?
