Urgent help needed: Page works in exe/preview, not in IE
September 4, 2012 12:00 AM
Wouldn't you just know that I went to test my course and discovered that a page which works perfectly in exe/preview mode is completely broken in browser (IE). I've got a TON of actions, including some math actions, and I"m guessing one of them is not compatible.
Mod Var (Modify Variable), value 1, add to variable 2 of these, targeting different variables
Mod Var, value 1, subtract from variable 2 of these, targeting different variables
Mod Var, value 1.06, multiply variable by
Mod Var, value 1.06, divide variable by
Mod Var, Round down variable
Mod Var, value VAR(variableName), subtract from variable
Mod Var, value VAR(variableName), add to variable
Change contents, target text box, value VAR(variableName) 2 of these, targeting different boxes, updating with different variables
Set Progress, target progress bar, value VAR(variableName) 2 of these, targeting different boxes, updating with different variables
This is the first time I've set up this exact type of interaction, but I'm sure I've used all of these actions individually and in different combinations before, with success. The only new one is the rounding one.
Of course, I can't upload a pic now (GRRRRR), but I'm happy to send one via email if additional explanation would be helpful. I'm also very available for phone calls, and am happy to return the favor any time!
Thanks in advance!
