Unresolved Destination Problem and other questions.
1. Keep looking, especially on the last page of the course.
2. You should have a chapter after your test with a page telling the user what to do now - maybe even two - one for passed and one for failed. Direct the test tabs for On Passed and On Failed to these pages. That may solve your problem.
3. If the grayed out Prev button shows but not the Next, then you may have disinherited the grayed out button too or something is covering it.
4. No effect on course other than taking up space. I always check the Delete resource from disk box and then tell it to delete the resources.
5. No idea here. Something is terribly wrong. Sounds like you have retained variables and have run the course before. If so, you may have to execute a Reset Test action at the beginning. Many times I put special commands / buttons to Reset the test or Reset All Variables during testing so I can see what it will look like to a new student. Then I delete these when I go to production.
