Trying to Learn About Variables and How and When to Set?
Your post referred to Completed with a capital "C." Instead, try completed with a lower case "c." It is case-sensitive.
As for when and where to set it, that's up to you. For example, you can put it as an action when the last page displays (on Show, modify variable...). However, if you have flexible navigation and the student can go to the last page at any time, you might not want that logic. You can make it dependent upon test results or other factors using the Condition tab. The key is to figure out on your own what "complete" means for this course. Once you know that, you can set up the logic to make it work in Lectora. If you know what criteria you want and aren't sure how to set it up, post it here and we'll help you figure it out.
