Tips for Events Synchronized to Audio
July 20, 2008 12:00 AM
So I called Trivantis support and they are aware of this. They hope to have this fixed in the next service pack (SP3?). In the mean time they suggested using Windows Media File Editor which can be downloaded for free. From the File Editor you would add a script (as opposed to a marker) to correspond to the Lectora event.What I ended up doing was using Sony Sound Forge to accomplish the same thing. I created a Text Command with the parameter being my Lectora Event.Regardless of the software you use save the file as a .wma. Imported the WMA into Lectora, set your events/actions and make sure the compression setting is checked during publish. This will converet all the .wma to flv.Using these steps eliminated that annoying sound defect is removed.Good luck
