Open Attachment in Offline Course doesn';t work
Note: I haven't updated to Ver. 18 yet, so still operating on Ver. 17.
I have a course that is published for offline use (exe). I have a few buttons in there that should open an attachment (pdf in all cases). The PDFs are all attached and show up in the resource manager. When previewing the course and when running the published course, clicking the button does not open the PDF. Running the debug mode shows that the action fires, but the action produces no results. Anyone have any ideas why it might not be working? Is it because it's an offline exe? I know this had worked in previous versions, but for some reason is no longer working as expected.
Discussion (5)
I'm on 17.1.7, not sure if that makes a difference. I'll try your other suggestion and see if that works. Thanks!
Make sure the computer it is running on associates .pdf files with Adobe Reader also make sure Adobe Reader is up to date. Reader can be finicky.
It's working for me with Lectora 17.0.6
You might try "Go to web adress" -> yourfile.pdf, which also works for me.
Thanks Darrel,
Although that makes me wonder... On my system it doesn't open and I have the full Acrobat DC included with Creative Cloud. And the person I have testing it I think is also on at the very least an Acrobat Pro version. Does Lectora limit its functionality to just Adobe Reader, or would either Reader or Acrobat work? Or any PDF viewer for that matter as long as it's set in the computer's defaults? Now, our customers themselves, or really customers' customers, would only have Reader installed so maybe just testing on a more similar system will verify.
Acrobat Pro has worked for me in multiple versions.
Note that all versions after 17.0.6 are known to be buggy.
