Matching Question Issue
You can't have a one-to-many relationship using Letora's "matching" question type. I'm not sure you'd want to do that even if you could -- think of it this way...if you were creating a paper-based test, a matching question that had multiple lines going to the same choice in several places would be awfully hard for the learner and the instructor to visually follow and correct, wouldn't it?For what you want to test for, try using multiple-answer multiple-choice questions. For example, you could have a question, "Which song(s) has the Dave Matthews Band recorded" and then have the whole list of songs as choices, with the correct answer being that they would have had to have chosen both "Two Step" and "Lie In Our Graves."Or, for another option that's less space-consuming, you can use the drop-down multiple-choice question type, where you list each song and have a drop-down list of bands next to it.There are other approaches in Lectora I could think of as well, but I think either of those should do quite nicely. Hope this helps!Laura
