LMSSetValue Error: Data Model Element...
Does your LMS support test and question interaction data? This is an optional component and not supported by all SCORM compliant LMS'. This option is determined in Lectora when you publish out to SCORM under the options tab. The second to last checkbox states something similar to, the course will report test and question interaction data to the LMS. Do you have this option selected for all the other courses that contain a test? If you publish out the course displaying this message, if you deselect this option, do you still get the error?Does your LMS support test and question interaction data? This is an optional component and not supported by all SCORM compliant LMS'. This option is determined in Lectora when you publish out to SCORM under the options tab. The second to last checkbox states something similar to, the course will report test and question interaction data to the LMS. Do you have this option selected for all the other courses that contain a test? If you publish out the course displaying this message, if you deselect this option, do you still get the error?
