Completion variable from Flash to Lectora
I know this is an easy answer, I just forget where to find it. I have a series of interactive exercises that I developed in Flash. I am running the SWFs in my Lectora title. I need to be able to pass a "completion" variable from the Flash exercises to Lectora so that a "button" on the interface will change colors when the user completes the exercise. So say I have 10 Flash exercises and 10 corrisponding "buttons" that the user can click on to navigate to the page containing that particular exercise. I want the user to be able to compete the exercises in any order and to easily see what exercises have been completed and which ones have not. I believe that there is some small bit of javascript code that i can put into the Flash exercise that will pass a "completion" variable to Lectora (at which point I'll set the "button" color to change). These exercises will not be passing any data to the LMS, just to Lectora so I can modify the button.Where could I find information on what javascript code to use and where to place it within the Flash exercise?Thanks!!
