Audio not working in Lectora 2008...
Or you could try un-checking the compression button for audio when publishing to HTML (on the compression tab) if your server cannot add the FLV as Mime Type; which is what I have had to do. Your files should then work as normal.Or you could try un-checking the compression button for audio when publishing to HTML (on the compression tab) if your server cannot add the FLV as Mime Type; which is what I have had to do. Your files should then work as normal.
