Lectora Audio Editor
August 18, 2009 12:00 AM
Events only work with .flv, .wma, and .wmv file formats. Since .wav doesn't support events, your file has to be saved in one of the other formats once you add your events.
cad76 said:I am running into a problem when trying to add events to audio using Lectora's Audio Editor. I have used this previously and never experienced this before. When adding my wav files and then through the Editor I put in any Events needed, I am being prompted to save the audio file as Windows Media Audio before I can move forward. This is causing me to have to go back into my Audio folder and retrieve the same piece of audio now as a WMA file and place that in the title. It works but it is annoying having to resave every piece of audio. Any idea why I am getting this prompt? Thanks so much, CAD76
