Audio Copy
If possible, I'd suggest placing the audio only once at the chapter level or above. This way you can inherit the audio onto each page as needed. This saves time and effort both up front and if you need to make changes later.Perhaps the echo you're hearing may be you have the audio placed on both chapter level and page level and they are both playing at once.
