Importing Questions
February 28, 2009 12:00 AM
A couple of great tips that help me with test questions. May or may not help you in this situation.1. Create a page that is the same size as the test question area (stretch out a text box to get the width/height). Create your test questions on this page. What this does is resizes the text boxes to fit into the appropriate space. Saves you having to manually resize everything. Once you have the question created, cut and paste the question into a Test page. 2. On the Test template, add two bisecting lines to help you place the questions in the same spot. I put my lines on the Test chapter, add my questions, then delete the lines.Since you're importing, these may or may not help you. Good luck.
