Print Problems
January 28, 2010 12:00 AM
omacron77 said:
I have a test result and Certificate page that is displayed and can be printed after the test. Both displays OK however, when they print there is problems. The test results page is blank in "Portrait" (default) mode and only half of the data prints out in "Landscape" mode. The certificate only prints half of the image or data. The test results page is generated by Lectora when selecting "customized test results" in the properties section of the Test and the certificate is created using the certificate wizard in Lectora. From what I can see there is no control I have on page adjustment prior to printing except on the printer itself. Has anyone else ran into this problem? Does anyone have a solution on how I can get these items to print out correctly? I will post the test in the files section for viewing under the name Printing Problems, it will be in Zip format.
