Test Problems
January 16, 2010 12:00 AM
Ben which booklet are you referring to for tip 5 ? I have made the changes and reuploaded the test see "Test Problems 3". When uploaded to the LMS and executed everthing works OK except the student name problem. You can view it at the following URL: http://www.screencast.com/t/OWI3N2M3N, I deleted question 1 and created a new one. Should I be getting the white background for the HTML document?
Ben, I have made the changes and uploaded another file for review Test Problems 2, I do appreciate your help in solving my issues.
Ben, thanks for the input, I will make the suggested changes and retry. Your E-books and tips on Lectora have helped me quite a bit on learning Lectora.
omacron77 said:I'm seeking help with 2 problems within the test chapter. The zip file has been posted in the "Files" section, the file is titled the same "Test Problems" or you can search by my user name. Problem 1: I have selected to have a customized report be available for printing and when executed it works as it should however, I would like to add the student name and date to the report. The report is automatically generated as well as the code for it. I have made multiple attempts to add the student name and date to the report successfully however when I do the score does not record properly. If I score 100%, 60% or what ever it always report 0. The code is located under the section titled "Test Results" and under the label Header, even if I create a text object for the date that's it the score will not record correctly and I cannot figure out why. Problem 2: I have added a progress bar in the test section only but it does not increment automatically, how can I get it to work properly within the test section?. Any help would be immensely appreciated. Please follow these 2 links for 2 videos to help explain my problems: http://www.screencast.com/t/NjQ4YWQ2, http://www.screencast.com/t/OGI3NTYzMmYt.
