Help with Randomizing Test Questions
December 29, 2009 12:00 AM
Jim, the test is being published to scorm. I reposted the test in the "Files" section, please do a search for "Test sample" and you will find it. I'll give your suggestion a try. Thanks.
omacron77 said:
I have about 200 test to configure so the questions are randomize. I have configured 3 to date, all 3 seem to work OK with the exception of one problem. The LMS we are using (Pathlore) will indicate only an "Enrolled status" once the test has been completed, If you score a "100" it should indicate a "Finished" but it does not. I have posted a copy of the AWT file for review in the files section, look same user name. Any help would be greatful.
