Help with Randomizing Test Questions
Although your subject references randomizing, your question appears on the test marking as complete on the LMS. I'll address that.
I'm assuming you're publishing to SCORM. We set up two pages removed from the course flow in a separate chapter: Complete and Incomplete. In the test properties: set the When Completed/Passed tab to go to the Complete page; set the When Canceled/Failed tab to go the Incomplete page. The Complete page has an action that modifies the variable AICC_Lesson_Status to "completed" (no capital letters!).
omacron77 said:
I have about 200 test to configure so the questions are randomize. I have configured 3 to date, all 3 seem to work OK with the exception of one problem. The LMS we are using (Pathlore) will indicate only an "Enrolled status" once the test has been completed, If you score a "100" it should indicate a "Finished" but it does not. I have posted a copy of the AWT file for review in the files section, look same user name. Any help would be greatful.
