Help with Randomizing Test Questions
 Ben, I have reposted the test File in zip format exported from Lectora. For some reason the file does not show in the "Files" section but if you do a search for "Test Sample" you will find it. Thanks for your help.
omacron77 said:
I have about 200 test to configure so the questions are randomize. I have configured 3 to date, all 3 seem to work OK with the exception of one problem. The LMS we are using (Pathlore) will indicate only an "Enrolled status" once the test has been completed, If you score a "100" it should indicate a "Finished" but it does not. I have posted a copy of the AWT file for review in the files section, look same user name. Any help would be greatful.
