Audio Stops When Buttons are clicked
June 23, 2005 12:00 AM
This is a known bug when playing audio files using the Windows Media Player plug-in within the IE. When the on click action takes focus, IE stops the audio playing within the Windows Media Player plug-in. We have tried various ways of working around this, however, the work around would cause the content to no longer be 508 compliant for screen readers. We are waiting for Microsoft to fix the issue. In the meantime, if you encode the audio using a format not played natively in the Windows Media Player such as RealAudio (.rm) it should correct the issue.
More From Charity
Completed Status Doesn't retain if return to course after completing
October 7, 2009 Reply 0 UpvotesCompleted Status Doesn't retain if return to course after completing
