Transition In/Out Problems
May 9, 2008 12:00 AM
Are you using variables to hide and show? If so, just do add an Action on Show of the page to Reset the variable(s). More than one variable, do Resets for all. It should fix you right up! Let me know!! Take CareCindi
More From Charity
Completed Status Doesn't retain if return to course after completing
October 7, 2009 Reply 0 UpvotesCompleted Status Doesn't retain if return to course after completing
