Events in Audio file not showing correctly
 Well, after much hair pulling, I got it figured out. I had 3 different audio files on the page that played at different times- all with events. It turns out that each separate audio file had to have the event named different. In all 3 audio files, the events were named the same (event 1, event 2, etc.) So after changing the event names in each file, it worked fine.
Thanks!
falcon44nkc said:Hello. I have an audio .wma file that I have added events to. Event 1 shows a group of text and images, Event 2 shows a group of text and images and Event 3 shows two links. When one of these links are clicked, new audio, text and images appears. This works perfectly in preview mode. However, in browser mode and when I publish, it isn’t working right. Text appears at each 3 events, but it is the wrong text. It is the text that isn’t suppose to appear until after one of the links are clicked. I’m using Lectora X. Any ideas? THANKS!
