Transition In/Out Problems
I was having the same problem when published to HTML. The fix is: Create and action on the transitioning out image that says, "on Hide, Move To, Target: your image, x coordinate (final position), y coordinate (final position).
In HTML the position gets gummed up on the transition out.
The image will still transition out (etc. fly left), but then once hidden, will move to the final position to in essence, reset itself to be able to transition in again.
Hope this helps! Susan
