Audio restarting issue
I'm using Lectora 2005 with the latest patch installed. I"m using a variable to capture page names and then automatically update a page name text field when I go from page to page. Same thing with chapter names, and page numbers.The problem is... I have audio (mp3) files on each page. When I publish the piece, then play it, when a page opens, the audio starts, then when a variable (finally) updates, the audio stops, and starts from the beginning again.The only work around I've found is to put the audio into a flash file and then insert that as an animation. But that is defintely not how it should be. Does anyone have any other suggestions?Thank you in advance!Dennis
