Thanks Dwayne.... I tried to attach an action to each of the buttons in the question, but it seems you can't attach actions to buttons for some reason. When you mentioned clickable object, I was assuming you meant the buttons?Thanks Dwayne.... I tried to attach an action to each of the buttons in the question, but it seems you can't attach actions to buttons for some reason. When you mentioned clickable object, I was assuming you meant the buttons?
