Questions and audio
wow... I've gone through about every possible scenario that you outlined above and nothing's working. It seems like it should logically. I have the question stem audio set as initially visible so that it will play on page entry, and the others set to invisible with what I think are the show/hide actions you're asking for above. Do you have any real examples that I could take a peak at to see where I'm going wrong?Thanks Aaron!
