Audio not playing correctly in IE10
May 2, 2013 12:00 AM
I am having a problem with audio not playing correctly in IE10.
I have review questions that are set up like this:
Audio A is playing at the beginning and the controller for Audio A is displayed. Then, then user clicks a button to answer the question. Then either Audio B plays and Audio B controller displays or Audio C plays and Audio C controller displays, depending on what they clicked.
In IE 8 and 9, this workds perfectly. But in IE 10 on Windows 8, when you click on the button, the audio doesn’t show or play.
Any ideas?
Discussion (1)
Can you publish a sample and put it online for us? Maybe the problem specific to your pc.
More From Charity
Completed Status Doesn't retain if return to course after completing
October 7, 2009 Reply 0 UpvotesCompleted Status Doesn't retain if return to course after completing
